Подбор оборудования
Подбор оборудования
Сообщение radiorecordua » Пн мар 15, 2021 7:37 pm
Добрый день уважаемые форумчане хотелось бы поспрашивать совета у бывалых по подбору оборудования может мой вопрос и не в тему форума (не знаю)
Что сейчас буду заказывать
1KW fm transmitter
RF Output Power: 0 to 1000 Watt,
1W/Step
Frequency range: 87.5-108 Mhz,
100Khz/Step
RF Output Connector: L29
RF Output Impedance: 50 ohm Audio
Input Connector: XLR type
AUX Input Connector: BNC type -
female
FU-DV2 1KW
Antenna
Frequeny Range:87.5-108mhz
Impedance: 50Ohm
Connector: EIA flange according to
system power rating
VSWR: <=1.3:1 MAX
Polarization: Vertical
SYV-50-12 cable
SL16-J to L29(DIN) 30meters
1202
channel mixer
12-channel audio 48V mixer
Each channel is equipped with a
post-fader effect transmission for
internal and external effects
1 stereo auxiliary loopback for
effects or as a stereo input
British equalizer
CD / tape input to main mix or
control room / headphone output
Analog mixer, high-quality ultra
MDX1600
Expander/Gate/
Compressor/Pea
k Limiter
Equipped with ultra-low noise
4580 operational amplifier and
advanced voltage control amplifier
The input and output level
(INPUT / OUTPUT LEVEL) and
gain reduction (GAIN
REDUCTION) are equipped with
12 indicators
"Traffic light" display function
makes the threshold setting and
de-sirens function clear
MDX1600
Expander/Gate/
Compressor/Pea
k Limiter
12 indicators
de-sirens function
200MKIII
Monitor Speaker
Item Weight:25.7 pounds
Product Dimensions:7.9 x 11.3 x
8.7 inches
Item Dimensions :L x W x H :7.9
x 11.3 x 8.7 inches
Color :Brown/Black
Monitor
headphone
Headphones Type: Wired
Whether the microphone: No
Headset service: Genius
Frequency response 18-20000Hz
impedance of 32 Ohms
48V condenser
microphone
M01
Mic arm
B02
Bop Cover
Large double filter Broadcast
Recording
Microphone BOP cover
On Air LED
light
Dimensions: outer size 40*20Cm
inside size 40*20Cm
Content: AIR ON
Phone Hybrid with
Feedback
Suppressor with
bluetooth and
phone line
connectivity
Phone Hybrid with Feedback
Suppressor with bluetooth and phone
line connectivity
Digital DJ
Controller Dish
Machine for Radio
Transmitter FM
Broadcasting
station
Type: 2-channel DJ controller
Corresponding software: Serato DJ
Sound card resolution:
24bit/44.1kHz
Frequency response: 20Hz-20khz
Signal to noise ratio: 105dB
Total harmonic distortion <0.003%
(USB)
Ко всему этому планирую добавить два сервера один под муз библиотеку второй под сервер icecast
три компьютера один под эфир второй под офис третий резерв эфира
Насколько такая конструкция будет жизнеспособна?
У кого есть опыт от дельного совета не откажусь
radiorecordua
Re: Подбор оборудования
Сообщение AndreyUA » Сб май 01, 2021 2:34 pm
Приветствую ... возможно уже не актуально,
1KW fm transmitter
Какая марка?
Если для профессионального вещания, я бы склонился к модульному усилителю, где отдельно возбудитель (обычно 1-35 Вт), и отдельно усилители сигнала. Если их несколько - то еще и комбайнер (сумматор). Это позволит масштабировать и менять модули в случае выхода из строя частями, как это к примеру реализовано у vigintos.
Компрессор, штука классная, однако он однополосный, что по сути уже не актуально, если хотите звучать не тише и не хуже конкурентов.
Тут стоит подумать о звуковом процессоре. При чем на первое время можно использовать в виде софта, к примеру Stereo Tools, либо аналоги. (да, версия для вещателей с примочками для FM - платная, однако оно того стоит)
В свое время даже статейку по этому вопросу подготовил. Конечно, я не писатель, однако материал пытался передать максимально полно, так как в инете таких статей не так и много.
При чем описывал развертывание радио на ПО от Влада.
https://habr.com/ru/company/nag/blog/407853/
Сообщение Trafik » Сб май 01, 2021 4:27 pm
1KW fm transmitter
Какая марка?
[/quote]
Это все линейка китайского FMUSER,...я так думаю©
Sound Empire 3.1.1 Build 132
Вернуться в Техника
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 0
